Noisy Power Steering Pump Pulley Bearing - 2002 Accord Coupe SE (4 Cyl)
Old Sep 7, 2010 | 08:45 PM
ken830's Avatar
Default Noisy Power Steering Pump Pulley Bearing - 2002 Accord Coupe SE (4 Cyl)
It's really obvious that the noise is coming from the pulley attached to the power steering pump. Sound is present and random during idle, but is much more pronounced when tugging the steering wheel back and forth. Sounds like a bad bearing.
Any way to replace the bearing only? Any other suggestions or insights appreciated as well. Thanks!
2002 Accord Coupe SE - 4 Cyl
Old Sep 8, 2010 | 07:08 AM
Looks like you can get parts for the pump. But first put on some belt dressing or even spray water on the belt. If that changes the sound, then your problem isn't in the pump but rather a slipping belt.
Old Sep 8, 2010 | 09:43 AM
deserthonda's Avatar
also make sure that it is not a worn o-ring sucking air i the system
Old Sep 9, 2010 | 03:06 AM
ken830's Avatar
Thanks! The belt looks okay at first glance, but you're right. It's definitely easier and cheaper to eliminate that first. Also... Any way you could include the legend identifying each of those components by name?
I did some searching before creating this thread and the o-ring thing came up and I initially thought that might be it too. But when I read more details, I understand that the sound is more like a moan or groan... The noise I'm hearing isn't constant , but when it occurs, it sounds slightly metallic... scraping? Very hard to describe...
Old Sep 9, 2010 | 06:41 AM
Cant put an ACTIVE link here because they're not a sponsor, but you can figure this out...
www dot hondaautomotiveparts dot com
click PARTS catalog
put in your car's information
select PS Pump/bracket as the category
also see PS hoses for the O-ring seal located where the hoses attach to the pump
ANYWHERE in the system, look for something that might leak & allow air to be sucked in.
Old Sep 9, 2010 | 01:37 PM
ken830's Avatar
Awesome! Thanks!
Old Sep 9, 2010 | 04:44 PM
Another idea to check out...
Down in the reservoir is a fine mesh screen, normally submerged in the fluid. If that gets full of gunk, the pump will have a hard time sucking fluid. Pump cavitation might be the sound you're hearing?
Old Sep 9, 2010 | 05:10 PM
ken830's Avatar
Thanks! I've read about that too! It's my wife's car, so I'll try to check it all out this weekend and will definitely provide an update.
swimguy
Feb 11, 2014 08:42 AM
joenintiesc
Apr 14, 2013 07:29 AM
pavman65
Mar 9, 2011 12:32 PM
oma93
Feb 6, 2008 12:43 AM
accordfan222
Oct 14, 2007 07:19 AM
