Noisy Power Steering Pump- 2007 Honda Accord
Old Feb 11, 2014 | 12:32 AM
swimguy's Avatar
Default Noisy Power Steering Pump- 2007 Honda Accord
My 2007 Honda Accord has been having a noisy power steering pump for the last 8 months. I would have changed the power steering pump however the noise only occurs in the morning- especially when its cold. I live in Southern California so its really never that cold (mid 40’s). Once I drive the car for a few miles the noise completely goes away (especially after driving high speed). Lately, the pump is making the noise every morning.
Immediately after the noise started I had the power steering fluid flushed and system bleed for air pockets. 2 months ago the dealer changed the return line on the system because of a recall on the power steering system. Still the noise continues! I noticed the power steering fluid looks a little frothy when the car is running. Don’t know if this is normal. Car has about 150k miles.
Can someone please advise me if I should change the power steering pump? Or have the fluid flushed again. Any ideas what might be causing the noise? The last time I flushed the system it only stop the noise for about a month. This is driving me crazy when I leave the house in the morning. Especially in front of the neighbors.
Old Feb 11, 2014 | 08:42 AM
Is this a V6 or IL4 engine?
PS pump is usually not the cause of this problem. It's a leaking oring on suction hose inlet fitting to the pump. Takes about 1/2 hr to fix. Your honda dealer should know this.
They always want to replace pump to fix this since pump is several hundred dollars compared to oring at $1.50.
TripleDTech
Jan 3, 2017 04:13 PM
JohnNH
Jan 15, 2014 05:23 PM
philipghu
Dec 30, 2011 08:59 PM
ken830
Sep 9, 2010 05:10 PM
tfunk
Jan 7, 2007 02:05 AM
