Power steering pump noise? 2006 Honda Accord V6
Old Dec 29, 2011 | 05:06 PM
philipghu's Avatar
Default Power steering pump noise? 2006 Honda Accord V6
Hi,
Sometimes there will be noise coming from the drive belt region when I start the car in the morning when the weather is cold. Some people say it is from the power steering pump. But the noise will disappear after I drive the car for like 15 minutes. Would it do any serious damage in the future if I just ignore this? The noise is recorded:
06 Honda Accord power steering pump noise? - YouTube
thanks!
Old Dec 29, 2011 | 08:24 PM
Cheap try....replace the o-ring on the pump.......mainly see this on the '03's (or so). Again for ~$2 worth a try.
Old Dec 29, 2011 | 10:49 PM
philipghu's Avatar
@poorman212: I can hear the noise when I'm not turning the steering wheel. The sound becomes greater when the engine revs up. Is it still because of the power steering inlet joint O-ring? Thanks
Old Dec 30, 2011 | 09:56 AM
EXV6NIGHTHAWK's Avatar
Usually, if it is the oring, the noise will be louder when the engine is cold, and quiet down as the engine warms up.
Old Dec 30, 2011 | 10:36 AM
listened to the video, and it sounds like the o-ring. The new o-ring will be orange, and they look a little thicker than the original black o-ring. It's a tight fit to get the 10mm wrench on the bolt and turn it, but it's possible. You will not lose much fluid, if you hold the hose up.
Old Dec 30, 2011 | 08:59 PM
deserthonda's Avatar
seen and replaced a bunch of these ,first thing i would replace , the o-rings sucks air into the system, seems to happen a lot more often on hondas and acuras with v6 engines
TripleDTech
Jan 3, 2017 04:13 PM
swimguy
Feb 11, 2014 08:42 AM
daftshadow
Jul 29, 2011 03:37 AM
akennedy89
Mar 5, 2010 06:55 PM
tfunk
Jan 7, 2007 02:05 AM
