Power steering pump noise? 2006 Honda Accord V6
Hi,
Sometimes there will be noise coming from the drive belt region when I start the car in the morning when the weather is cold. Some people say it is from the power steering pump. But the noise will disappear after I drive the car for like 15 minutes. Would it do any serious damage in the future if I just ignore this? The noise is recorded:
06 Honda Accord power steering pump noise? - YouTube
thanks!
thanks!
listened to the video, and it sounds like the o-ring. The new o-ring will be orange, and they look a little thicker than the original black o-ring. It's a tight fit to get the 10mm wrench on the bolt and turn it, but it's possible. You will not lose much fluid, if you hold the hose up.
seen and replaced a bunch of these ,first thing i would replace , the o-rings sucks air into the system, seems to happen a lot more often on hondas and acuras with v6 engines
TripleDTech
Jan 3, 2017 04:13 PM
