04 Honda Accord; 4-door sedan; brake lights not working
Old Oct 10, 2019 | 03:27 PM
ProfessionalAgno's Avatar
Default 04 Honda Accord; 4-door sedan; brake lights not working
Hello,
So I don't know a lot about cars honestly, so you'll have to excuse my lack of knowledge for certain terms
Basically, my 2/3 of my brake lights do not work. The lights housed with the turn signals do not work. The light above the trunk, on the spoiler, does work.
I went to a local auto parts store to grab new brake lights, and it turns out it was neither the bulbs, nor the fuses. The guy told me it was most likely a wiring issue. So I'm just wondering if there could be any other possibly explanations for why it's not working, a way I could fix it myself, or an estimate to how much it would cost to fix
Thanks!
Old Oct 10, 2019 | 08:14 PM
Sounds reasonable that its a wiring issue. Do the taillights work? Back-up lights? Turn signals?
You've been in there to replace the bulbs, right? First thing is try to follow the wires from the bulb sockets. You may have to peel back parts of the trunk lining material. Look for anything cut, pinched, or screwed up in any way. One of the wires will go to some kind of screw or bolt on some metal part of the car; that's the ground wire. Make sure it's clean & tight.
I don't have a shop manual for 2004 so I hope someone chimes in...
Giles Siadous
Aug 20, 2018 09:20 AM
csh217
Apr 30, 2013 09:03 PM
05 EXL
Aug 5, 2009 11:58 AM
arunsam3000
Mar 6, 2007 01:40 PM
