'05 Accord error codes - P0780, P0796, P1733
Old Nov 27, 2022 | 09:39 AM
Rgbtexas's Avatar
Default '05 Accord error codes - P0780, P0796, P1733
Last week my daughter's '05 Accord had error codes P0780 & P1731.
I checked the trans fluid. It was at the right level but looked dirty.
I changed the transmission fluid and drove the car. It seemed fine again. This morning she went to drive it and started having shifting issues again.
Now it's showing error codes:
P0780, P0796, P1733
Error codes
i couldn't change the filter because there were none available anywhere near me. I need to order it.
​​​​​​What else do I need to do with this? Is this replace or clean the pressure control C solenoid? Or, is there something worse?
Old Nov 27, 2022 | 11:12 AM
I think the filter is internal on that transmission where you essentially have to disassemble the transmission to replace. Does your accord have an in-line external filter?
When you changed the transmission fluid, did you do just one drain/refill? Each drain/refill takes ~3 quarts.
For the solenoid, you can try removing and cleaning any debris out of the solenoid. I don't know how difficult it is to access. You can also try supplying power to the solenoid to listen for a click.
Old Nov 27, 2022 | 11:31 AM
Rgbtexas's Avatar
Thanks for the reply.
Yep, it has an inline filter like this:
I did one drain/refill because I figured I needed to drive it a little to help clean out any dirt & debris that may have accumulated and blocked any solenoid screens from the 1st set of error codes. I planned on doing it again when I get the replacement filter this week.
I just don't know if it's just the "C" selenoid or if I have to worry about all of them.
Old Nov 27, 2022 | 11:55 AM
I think the B and C clutch pressure solenoids are one assembly, so you can remove the solenoid(s) and look for any obvious debris that can cause your issues.
When you drained the trans fluid, did you see any metal shavings in it? To exchange most of the fluid, you should do 2 more drain/refills. Just do some driving in between to mix the new and old fluid.
Old Mar 11, 2026 | 11:20 PM
Lucas92's Avatar
Default Pudistes
La semana pasada, el Accord 2005 de mi hija tenía los códigos de error P0780 y P1731.
Revisé
el líquido de la transmisión. Estaba en el nivel correcto, pero se veía sucio.
Cambié el líquido de la transmisión y conduje el coche. Parecía estar bien de nuevo. Esta mañana fue a conducirlo y empezó a tener problemas con los cambios de nuevo.
Ahora muestra los códigos de error: P0780
, P0796, P1733. No pude cambiar el filtro porque no había ninguno disponible cerca de mí. Necesito pedirlo. ¿Qué más necesito hacer con esto? ¿Es esto reemplazar o limpiar el solenoide de control de presión C? ¿O hay algo peor?
Pudistes solucionarlo de que manera
Old Mar 11, 2026 | 11:21 PM
Lucas92's Avatar
P0780, P0796, P1733
Error codes
Cómo lo.solucionastes tengo los mismos códigos
serta1
North East
Nov 18, 2024 10:59 AM
Big Guy
Nov 4, 2019 07:42 PM
ExEvolution
May 9, 2013 11:59 AM
nufftalon
May 31, 2011 05:30 PM
Breezy1
Jan 4, 2008 12:58 PM
