05 CEL reset?
Old Apr 8, 2012 | 10:09 AM
LS-300's Avatar
Default 05 CEL reset?
On my 05 Accord I had an engine code and think I have fixed the problem and want to reset the CEL to see if I actually did fix it. On my 99 you pull fuse #13 (clock/back up) in the panel on the passenger side. Is it the same for the 05?
Old Apr 8, 2012 | 04:10 PM
You can try pulling the ECU fuse, #8 (15A) located in the under-hood fuse/relay box for several minutes.
Old Apr 8, 2012 | 05:43 PM
Or you can go to an autozone/advanced auto and they might clear it for you(they aren't supposed to but many do).
Old Apr 11, 2012 | 09:40 AM
Beginning in 2003 they use non-volatile memory so disconnecting the battery will not clear it.
Whether or no parts stores will clear it for you seems to differ state-to-state. I've had them do it here in Ohio. Stories about them refusing to clear it seem to come from California.
Old Apr 11, 2012 | 10:17 AM
Dr. Drivability's Avatar
Curious, what was the code and what did you fix/replace?
Old Apr 12, 2012 | 09:20 AM
LS-300's Avatar
Code 1457
Replaced the gas cap and so far so good.
Most auto places around me won't reset the code due to liability crap.
Old Apr 12, 2012 | 10:21 AM
Yup, that code is related to the EVAP system, loose, bad or missing fuel cap, just an FYI, Honda has replaced that code with P0457.
Reboticon
Aug 24, 2010 06:50 AM
Breeze
Jul 23, 2006 01:04 AM
avs0730
May 21, 2006 08:21 PM
darryltravis
Apr 25, 2006 09:23 PM
HondaLawgik
Apr 16, 2006 04:19 AM
