05 exl 3.0 accord misfire issues and p0497 need help
Old Jun 6, 2018 | 11:18 AM
Ryanhmike's Avatar
Default Help please
OK so my gf has a 2005 accord exl 3.0 issue is she drove the car with check engine light on and knowing thier was codes read and cylinder 1 and 5 misfire she did nothing about it well I started to notice longer time from crank to start and rough shaky idle I took liberty of buying 6 new coil packs and spark plugs well after I did the work after driving one mile it starts to fell like it is going to die almost surging felling idel it's really bad when accelerating its good like normal get to speed n keep steady it dose the I call it skipping it fells like it is slipping in n out of gear ran the codes cylansder 3 confirmed and random misfire she drove it a week like this ran codes again 2 and 3 misfire it almost don't want to start when it's been driving for 20 min and is warmed up how do I correct this misfire and hard start issue where do I began I'm also being thrown a p0497 code evap system low purge I don't want to throw money at it n not correct issue I love the 7th gen 3.0 but it's running like crap I did put in new pcv valve did change anything n I'm so lost onto y after new coil packs n plugs it still misfire just.moved any advice on where to start it be greatly appreciated
Old Jun 6, 2018 | 11:36 AM
Ryanhmike's Avatar
Default 05 exl 3.0 accord misfire issues and p0497 need help
Had made a previous thread it was jumbled n didn't make sense even to me. So 2005 accord exl 3.0 had misfire cylinders 1 and 5 ignore issue (gf car) well could no longer ignore idel was getting bad shaky n louder also starting the car had gotten worse like it had to crank 3-5 second before start. I bought all new coils n plugs and installed starting car was same but driving it was jerk n shaky at idel or low speed but if we're steadily accelerating no issues at all but got to steady speed could fell the jerking I knew it was a misfire ran codes number 3 misfire confirmed 2456 pending random misfire she drove about 50 miles ran codes again cylinder 2-3 mis I need help on where should I began I don't want to throw money at it and it not be the solution
Old Jun 6, 2018 | 11:54 AM
Errol Hoberman's Avatar
Help with what?
Give the subject of your request, more people will open it.
Old Jun 6, 2018 | 06:12 PM
I merged your threads, since they are dealing with the same issue.
Can you let us know all the current codes on your car? Do you have a code reader/scanner? If yes, can it read live engine data?
rlmedina321
Nov 12, 2013 04:28 PM
phantomgrey92
Aug 22, 2013 07:42 PM
JDS06EX
Feb 22, 2013 02:42 PM
Cummins_Turbo_Diesel
Jul 25, 2011 08:48 PM
Racemaster
Feb 27, 2011 10:42 PM
