'06 Accord Coupe V6 "engine not cranking"?
Old Feb 14, 2013 | 06:03 PM
I had a 2.5L Acura TL and it had a similar appearance solenoid. It was a permanently sealed unit and not repairable. The repairable units have a trapezoidal shaped cover that can be removed.
Old Feb 14, 2013 | 09:00 PM
I guess what I meant is apparently the sealed solenoid can be replaced instead of the whole entire starter.
Old Feb 15, 2013 | 12:07 AM
L2_DJ's Avatar
Thanks guys for the fast response, I really do appreciate it.
So the Honda dealership and my mechanic found out that the problem was the starter. Do you guys recommend I should get a new starter from Honda dealership ($550 with labor) or remanufactured ($400 with labor)?
Old Feb 15, 2013 | 04:54 AM
shipo's Avatar
Remanufactured means that all parts are brought back to "new" spec; I never buy new starters or alternators, just remanufactured ones.
Old Feb 15, 2013 | 08:25 AM
Either is probably OK. Acura parts are the gold standard. Starters from auto parts stores are known for "out-of-box" problems. However this would be the shop's issue not yours, but could require another trip to shop.
I like to re-use my own starter w/ a rebuild by a starter/alternator shop. Costs about the same as rebuilt from auto parts, but I have more confidence in the rebuild of my own starter.
Old Feb 15, 2013 | 09:01 AM
shipo's Avatar
I too try to avoid "rebuilt" starters and such, however, I have always had very good results when using "remanufactured" (there is a significant difference between the two) components.
opaque
Apr 22, 2013 12:17 AM
hondachic
Aug 6, 2012 11:40 AM
Lurch
Dec 7, 2011 07:55 AM
tinkerevil
Apr 23, 2011 02:52 AM
5.0stang
Jul 23, 2009 07:24 PM
