06 Accord Driver Door Issues
Old Nov 20, 2011 | 10:31 AM
Tenorman51's Avatar
Default 06 Accord Driver Door Issues
Hi folks. My wife and I got this Accord about 18 months ago. Not long afterword, I decided the car had been wrecked in the left front fender and it effected the door. Here's the issues I'm having. The power window is slow, and usually makes a terrible squealing sound going down, sometimes up. The controls for the door locks in that door usually don't work. The speaker works sometimes. The door leaks water in the rain. The remote unlock usually don't work.
I went to pop the door panel off and didn't see anything that lent itself to removal. I suspect clips that'll have to be replaced and several hidden screws. I checked the forum and no one has talked about opening up a door on this model year Accord.
I'm really hoping I can solve these issues without replacing the door. The biggie for me right now is getting that window to work properly without the squeal.
Thanks for your input.
Old Nov 20, 2011 | 10:38 AM
I had probably a related experience. I left window in my 07 Accord down during a light shower. Windows would not work. I let it dry out over night and problem disappeared.
Removing the door panel is not hard, but use of a shop manual is recommended to avoid damaging the door panel. Suggest purchasing an emanual from ebay seller automanualsource for $21.99. I've purchased two from him and they are easy to use emanuals.
I looked at my 03-07 manual and it's slightly different than earlier models, but similar. All fasteners are re-usuable w/ care in removal.
You may have a damaged window run channel that is allowing water to get into window and cause problems. This does not mean car was wrecked, but it's possible.
Old Nov 22, 2011 | 09:22 AM
Tenorman51's Avatar
Default Door Issues
Thanks for the 411 TXHonda. I did fail to mention, the door is warped some, the top sticks out away from the jamb about 1/8". That's where the water is coming in at. The door also rubs the fender when you open it and the hood isn't aligned properly. Also, there's paint overspray obscuring the pinstripes on the left side of the car. Yea, I think it was wrecked. I'll be getting those manuals. Thanks again.
frankenstein69
Dec 28, 2014 12:36 AM
Rob2000AccordLX
May 9, 2014 06:23 PM
jza240sx
Apr 30, 2013 04:14 PM
nismogrendel
Feb 7, 2013 07:03 PM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
