06 Accord Headlights Problem
Old Dec 5, 2011 | 11:47 AM
arista blouin's Avatar
Default 06 Accord Headlights Problem
I have a 2006 Accord. The low beam lights are no longer working. Running and high beam lights are fine. Fuses are good and replacing the bulbs didn't work. I want to check the dimmer switch, but have no idea where it is. Also, is the dimmer switch the same thing as the headlight switch?
Old Dec 5, 2011 | 02:01 PM
joec44's Avatar
I looked at the ckt. the dimmer switch and the headlight switch ar part of the combination switch first did you check fuses #3 7 21 in under dashbox?also fuses 1 3 5 6 in under hoodbox? If it is not a fuse your are in for a long ride on this one becous it uses the multiplex control lines and the relay control module under hood. So check fuses and check if you have power or ground at the lits post and I will try to help
Pilot Mobbin
Jan 30, 2013 07:18 AM
yamban
Oct 9, 2010 07:32 PM
bwhillzy
Aug 28, 2008 11:48 PM
Slither1989
Apr 11, 2006 02:10 PM
Slither1989
Apr 10, 2006 08:59 PM
