06 Honda Accord - Any help?
Old Aug 7, 2011 | 02:21 PM
blalock7's Avatar
Default 06 Honda Accord - Any help?
I got an 06 Honda Accord that seems to be missing upon shifting. Its not really a hard shift, but more like its not getting enough fuel. If you start off from a complete stop at grandma speed (ha) giving it easy gas it seems to pull thru the shifts fine, but if you take off at normal speed it seems to miss really bad upon shifts..It may hold that miss for moment, or may just miss and switch on..I cant get it to get the codes until tomorrow, but thought someone might have a suggestion on what it could be.
Its been maintenanced well, and what not. I have a check engine light that looks like a transmission, and one that looks like a wrench..This isnt my car so I am unfamiliar with Honda icons..
If anyone can give any feedback/possibles here I would greatly appreciate it.
Thanks
Old Aug 7, 2011 | 02:51 PM
piggylover1985's Avatar
I would get the codes and description of the codes and post them here so the guys here can help, could be something minor like a pressure switch or an MLPS, or could be something on the engine side, but try driving it easy so the transmission won't get hurt too bad, i'd seen sometime people keep driving with a bad pressure switch for a long time, and when they coming to have the pressure switch replace the damaged was already done internally.
Old Aug 7, 2011 | 03:18 PM
blalock7's Avatar
Thanks piggylover - The code is actually something I was NOT expecting, but you know how that goes...
P2467 - A rocker arm actuator system stuck on on bank 1
Old Aug 7, 2011 | 03:47 PM
blalock7's Avatar
Ok talk to a friend and he suggest changing the oil, and getting a good filter on it..Owner says it is time for an oil change..So we are going to try this...Ill let yall know how it goes
Old Aug 7, 2011 | 04:03 PM
That don't sound good, make sure the oil level is full, do you have any kind of warranty on your car ?
Old Aug 7, 2011 | 04:11 PM
Code should be P2647. It's a circuit fault High Voltage. This would likely mean an open circuit. Bad wire, connector, or open solenoid coil.
Manual says to check oil level, reset ECU, and see if code immediately returns. If yes, then find the electrical fault.
Old Aug 7, 2011 | 04:12 PM
I think your code is p2647.
Old Aug 8, 2011 | 02:20 AM
blalock7's Avatar
Thank you all SO very much for your help..Right now I have changed the oil, and it seems to have helped...Its my best friends car but I think we are going to go try to trade it in tomorrow..Just seems it may be time..I do appreciate the help greatly.
junkmonkey99
Dec 19, 2011 11:30 PM
ReDxAcCoRdx509
Jan 6, 2011 04:51 PM
mamtsberg
Mar 17, 2010 09:15 PM
tryonline
Jan 20, 2009 06:38 AM
uthustler
Dec 16, 2007 12:24 PM
