06 SE Manual High Idle at startup
Old Dec 12, 2006 | 12:43 PM
p3z
Default 06 SE Manual High Idle at startup
I have a 06 SE with a manual transmission. When I start the car with the clutch down it idles at about 1500. When I put the clutch in and have it in neutral it stays around 1500 for a few seconds and then drops down to around 950 or so. Is the higher idle just because there's no load on the engine or should I be concerned?
Old Dec 12, 2006 | 03:14 PM
hondadude's Avatar
Default RE: 06 SE Manual High Idle at startup
Cold start fast idle?
Old Dec 31, 2006 | 05:08 AM
p3z
Yup. I did some reading and I think it's programmed to warm up the engine by idling faster on startup.
Old Dec 31, 2006 | 08:43 AM
YeuEmMaiMai's Avatar
when it is colder outside the engine automatically idles at a higher rpm as well as run a little bit richer until it warms up
MICHOASTYLE
Mar 15, 2012 06:16 PM
longtimeowner
Sep 28, 2011 11:33 AM
cryptonate
Nov 12, 2009 05:09 AM
stangmanx
Oct 1, 2008 01:04 PM
Jason29
Jan 17, 2007 12:58 AM
