07 Accord, 5 spd, leaving in gear does not stop roll
Old Nov 4, 2010 | 08:53 AM
TomC's Avatar
Default 07 Accord, 5 spd, leaving in gear does not stop roll
Hi all,
I have a 2007 Accord SE, 5 speed, 4 cyl.
Recently I have noticed that when I park on a hill and leave in gear, many times the car will still roll. It happens about 50% of the time. Doesn't matter which gear, the same thing happens. It does not pop out of gear, but it does jerk a tiny bit and then will continue to roll until I take further action. This happens in both directions.
Any suggestions would be much appreciated.
Thanks,
Tom
Old Nov 5, 2010 | 01:26 PM
Handbrake.
Sounds like the hill is steep enough to make the engine spin. See, a manual transmission doesn't have a positive lock like when you shift an auto into "P". That's why they used to teach in drivers-ed to turn the wheels against the curb when you park on a hill.
Reverse is usually a numerically lower gear than 1st, so many times it's better.
Old Nov 6, 2010 | 10:10 AM
TomC's Avatar
Thanks for your reply.
Unfortunately this happens on slight hills as well.
I have been driving various sticks over the years and there is definitely an issue here.. (Happens when using reverse as well)
Old Nov 6, 2010 | 02:21 PM
It's the engine's compression that holds it. Does your engine run like it has weak compression? I normally use the handbrake when I park, but it seems like it would take a steep hill to turn over the engine. I can't really think of another reason at the moment.
Old Nov 8, 2010 | 09:16 AM
TomC's Avatar
Thanks.
I'm not sure what driving would low compression would actually feel like.
I may be wrong on this but in my cars in the past, when I parked on a hill I would drop it into gear and let it catch then i would use the handbrake.
I scheduled an appointment at the dealership I purchased the car at (I bought it over a year ago, large honda dealership). Will post what they tell me immediately afterwards!
Old Nov 8, 2010 | 10:08 AM
Low compression just feels like it has less power. I guess that's a pretty silly description, unless you've driven a few other 4-cyl Accords for comparison.
Old Nov 8, 2010 | 05:42 PM
How does the clutch feel. Is there any kind of oil leak from the rear main seal.
renzovc16
Dec 11, 2012 05:36 PM
spiker369
Jun 16, 2011 01:46 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
badxdawgx818
Sep 4, 2007 03:36 PM
ksorbo
May 24, 2007 11:20 PM
