94 Accord Radiator Fan does not stop running
Old May 24, 2007 | 10:28 PM
ksorbo
Default 94 Accord Radiator Fan does not stop running
I have a 94 Honda Accord with 170,000 miles.
Just tonight when my wife came home, the radiator fan would not turn off for several minutes. No lights showed overheating. Started up the engine let it run, sprayed the radiator. Turned off the engine. The radiator was actually cool enough to be able to touch. Fan still running.
The fan ran for 5 minutes or more with no sign of stopping. I disconnected the battery to keep it from discharging.
Any ideas what is wrong?
I assume it is some type of thermostat. Where is it? Is it something that I could change myself?[/align]
Old May 24, 2007 | 11:20 PM
Default RE: 94 Accord Radiator Fan does not stop running
Follow the upper radiator hose to the engine. There's a 'sensor' in that hose nipple. Unplug it & the fan should stop running.
There's alsoa fan timer module that turns off the fan after 15 minutes, even if that switch is stuck. Have you waited long enough to check whether this works?
moey
Aug 29, 2014 08:03 AM
Novaknowledgenow
May 30, 2013 08:58 PM
CDJDM07
Aug 24, 2011 09:51 AM
mjquillici
Mar 21, 2011 10:59 PM
