07 Accord V6. AC clutch not engaging and condenser fan not coming on
Old Aug 20, 2017 | 06:12 PM
Swiftcat's Avatar
Default 07 Accord V6. AC clutch not engaging and condenser fan not coming on
Cannot figure out why AC will not work. AC shows on on dash but compressor clutch does not engage and condenser fan does not come on. Blower works fine on all settings. Compressor, condenser, expansion, valve, drier, and AC pressure switch have all been replaced. System was vacuum and charged. Pressure is good. Can jump both the compressor clutch and condenser fan at the relay and both operate just fine. Any ideas?
Old Aug 20, 2017 | 09:32 PM
The common DIY thread on top of the gen tech help forum has a HVAC diagnostic procedure you should try. That may help direct you what to test next.
Old Aug 21, 2017 | 06:23 PM
Swiftcat's Avatar
Have tried diagnostic procedure. Shows no codes. Have also went through the AC pressure switch troubleshooting from the shop manual. Seems as if the Ecm is not grounding pin on relay to engage the compressor clutch.
Old Aug 22, 2017 | 01:46 PM
See attached circuit diagram. I did not have an 07 manual.
If no ground signal is arriving from ECM/PCM then either faulty ECM/PCM, wiring fault on inputs, faulty Relay Module, faulty Gauge Control Module, or fault on Climate Control board.
Difficult problem to diagnose w/o sophisticated Honda HDS.
Check for Ground pass-through at the Relay Module. Absence of ground would inhibit AC system.
File Type: pdf
Old Aug 22, 2017 | 05:29 PM
Swiftcat's Avatar
Thanks for the info. When you say the relay module, is that something other than the AC clutch relay? If so, do you know where that is located?
Old Aug 23, 2017 | 10:02 AM
It's a different relay or component in the under hood fuse box. See diagram note *1.
The Relay Module's design/function is unclear. Some type of isolation device presumably.
auto_troubleshooters
May 31, 2012 09:24 PM
CDJDM07
Aug 24, 2011 09:51 AM
foxies
Dec 23, 2010 05:31 PM
dptucunduva
Aug 5, 2007 02:44 PM
southnash
Jul 3, 2007 10:49 PM
