'07 Accord without Low Beams
Old Dec 18, 2009 | 10:39 PM
shatturn5
Default '07 Accord without Low Beams
Hello. My '07 Accord suddenly lost both low beams. There is a separate fuse for each light so I don't think a blown fuse is the problem. Any suggestions?
Thanks
Old Dec 19, 2009 | 02:45 PM
It could be the relay or the headlight switch on the steering column.
If there is an identical relay next to the headlight relay (like a power window), you can swap them. If the headlights start working, and the power windows stop working, then you should replace the relay.
Old Dec 19, 2009 | 08:03 PM
finch13's Avatar
There is a relay control module in the underhood fuse box. It has 3 relays for low beam, high beam, and exterior/tail lights.
There is also an MICU (@ under dash fuse panel) and Combination Switch Control Unit (@ washer/wiper switch) that the headlamp/turn signal switch must go through to control the lights as well.
Do the high beams work? If the high beams are operational, you can rule out the CSCU and the MICU as between those components and the relay control module the signals are multiplexed.
Old Dec 22, 2009 | 11:12 AM
shatturn5
Default Re:'07 Accord Without Low Beams
I went to the Dealer as I could not determine the cause (thank you for your suggestions) and come to find out, both bulbs burnt out at the same time!...go figure.
Old Dec 22, 2009 | 11:45 AM
Wow, I guess you always gotta check the easy stuff first just to rule it out.
Old Dec 22, 2009 | 12:04 PM
poolman's Avatar
If you installed Nighthawks or Silverstars, chances are they burned out together. I have had that happen on 2 of my cars.
Old Dec 22, 2009 | 12:07 PM
kris_loehr's Avatar
What happens a lot is one blub burns out and the driver doesn’t realize it until the other one burns out also.
otrawj
Feb 27, 2014 03:50 PM
Hondahonda
Dec 2, 2011 10:55 PM
bodie
Apr 19, 2011 11:19 AM
Smudgie
Sep 2, 2009 06:35 AM
jasoncook3
Dec 28, 2005 10:10 PM
