07 Engine blown - 4 cyl EX-L 5sp manual
Old May 1, 2014 | 01:51 PM
Rob2000AccordLX's Avatar
I would get a second opinion. Something doesn't sound right. Maybe the timing belt broke? Do you know if it was ever replaced?
Old May 1, 2014 | 04:05 PM
The car doesn't have a timing belt. It has a timing chain.
What may have happened was that the car was ran with low oil levels or infrequent oil changes over a period of time, which can cause the timing chain to get stretched. Which over time, can also cause damage to the engine due to bent valves, etc.
When there is a flickering or blinking Check Engine Light, you shouldn't continue to drive it. A flickering/blinking Check Engine Light is not the same thing as a steady Check Engine Light being on.
vetski179
Aug 19, 2015 08:32 PM
davntaz
Apr 11, 2015 09:10 PM
j894
Apr 18, 2013 05:59 PM
linden
Dec 9, 2012 12:09 PM
az4438
Oct 28, 2011 08:30 PM
