08 Accord ex led drl
Old Feb 7, 2016 | 03:32 PM
ex08's Avatar
Talking 08 Accord ex led drl
Hello,
First time posting, long time reader of forum. I have a 2008 accord ex, trying to install drl led strip. Where would I tap into the under hood fuse box. Checked for ACC and found all fuses are active when car is off and key is out. What fuse or relay can I tap 12V ACC from that will turn on drl strip with the car started and off when the car is turned off and key is out.
Fuse # or fuse box pic would be a great help.
please help
thanks in advance to all who respond, I've learned a lot from this forum.
Old Feb 7, 2016 | 05:30 PM
Driver's under-dash fuse box would have fuse slots that are hot in START or ON. Fuse slot no. 1 and no. 2 are unused.
Old Feb 8, 2016 | 11:24 PM
ex08's Avatar
Thanks redbull, but I don't know how bring the wiring inside the car under driver side dash... so I wanted to use the under hood fuse box.. which fuses are hot under hood fuse box when in start.
Old Feb 9, 2016 | 07:20 PM
1. The fuse slots that are hot in START or ON are located in the driver's side under-dash fuse box, as stated in my first post. Get a Littelfuse Add-A-Fuse MINI and use one of the unused slots in the interior fuse box. No. 1 and 2 slots are unused and readily accessible in the lower right-hand corner of the fuse box when you look up under the dash. You will have to run one wire for power ( +) into the interior doing it this way.
http://www.littelfuse.com/~/media/Fi...FHM02FHA02.pdf
Just because you may want easier access in the under-hood fuse box, does not mean it is there.
2. If you want to run the power wire to the interior, there is a pre-drilled hole with rubber grommet at the firewall. You probably can make a cut in the grommet to run the wire through.
Attached Thumbnails 08 Accord ex led drl-8980d1354549875-new-here-i-wanna-put-some-leds-my-front-grill-09-accord-firewall-hole.jpg
drive_h0nda
May 28, 2013 09:58 PM
HondaPower
Oct 24, 2012 05:34 AM
rppauto
Mar 11, 2012 08:19 AM
CapeMayAl
Aug 10, 2009 08:07 AM
thisismrjd
Feb 27, 2009 04:04 PM
