08 V6 removal
Old Aug 13, 2012 | 03:29 PM
SubaruTech84's Avatar
Default 08 V6 removal
Hey everyone. I am new to the Honda world. I am a Subaru Master Tech. I am looking at buying an 08 Accord Coupe AT with a 3.5L. It has a blown engine. I am doing some research before going ahead and doing it. ALLDATA procedure shows to drop the engine/trans as an assembly out the bottom of the car. I don't want to go through all that trouble if I don't have to. So is there anyone out there that has pulled the motor out the top of the car??? Any help is appreciated!
Old Aug 13, 2012 | 09:58 PM
Anyone out there done this before?
Old Aug 13, 2012 | 10:07 PM
I don't see why you couldn't pull the engine out from the top of the car.
Either way, it will be a lot of work to pull the engine.
Old Aug 14, 2012 | 12:05 AM
Dr. Drivability's Avatar
O.E. site has the same procedure to remove from under car...same as Alldata...which processes info direct from Honda, word for word, pic for pic. One can never assume, but I would guess they published the easiest procedure to remove the engine/trans assy.
Old Aug 14, 2012 | 07:14 AM
I'm sure they publish the easiest procedure for a repair facility to remove the assembly. But I plan on doing it in my garage. I've pulled dozens of engine/trans assemblies out the bottom with the subframe. But that was in the shop where I could just secure the subrame with the engine/trans on a roller and lift the body above my head. I am sure it can be done, I guess I was hoping to hear someone has done it before. LOL
Old Aug 14, 2012 | 08:24 AM
try a Youtube search...some guys like to video tape service procedures...although i'm sure that video would be fairly loooooong.
Old Aug 14, 2012 | 11:10 AM
This guy lifted the engine from the top on the previous generation Accord V6; but, he did remove the subframe underneath.
"honda-tech.com/showthread.php?t=2863368"
Old Aug 14, 2012 | 01:48 PM
Thanks! That was a good read, but he actually dropped it all out the bottom. He had some sort of ramp or hoist that lifted the car high enough to drop it all out the bottom.
ryan ortego
Dec 4, 2005 04:10 PM
theycallmerickjames
Oct 10, 2005 06:57 PM
commodore
May 19, 2005 11:11 AM
77911S
Apr 27, 2005 09:51 PM
toicy4ya
Apr 17, 2005 01:24 PM
