09 PCM failure
Old Jun 15, 2019 | 07:37 PM
mannhalr's Avatar
Cool 09 PCM failure
With 40k miles on our very well kept v6 EXL the engine malfunction light came on. Had the codes checked at O'Reilly and showed P3400 and P2648. Had it checked out with one repair shop and two Honda dealers. The first dealer found the rear rocker arm oil control solenoid shorted out. They replaced the rocker arm oil control valve assembly performed reset but code returned when valve pause activated. Second dealer checked this and concurring with the other shops, recommended replacing PCM. They explained they had never seen a PCM fail and was their first. So now we wait for a new PCM loaded with the required software for our car. My question is, has anyone else had to replace the PCM Power Control Module because it failed?
Old Jun 16, 2019 | 12:29 PM
Seanjordan20's Avatar
No but there is definitely a recall for your issue depending on your build month.
https://auto-recalls.justia.com/hond...009/11v395000/
Old Jun 16, 2019 | 02:23 PM
mannhalr's Avatar
Thank you for your response and will bring this TSB up with the dealer where the car is waiting for a new PCM.
jeffk14
Oct 21, 2011 11:32 AM
cypherdtraitor
Jul 16, 2011 02:24 PM
ufosearch
May 18, 2009 03:10 AM
blazinfnestyle
Mar 19, 2007 06:02 PM
