1982 accord few issues..
Old Mar 27, 2006 | 04:23 AM
gsdreams's Avatar
Default 1982 accord few issues..
After a recent engine swap I've been fixing everything the person who performed the work for me did wrong. I didn't have a location to do it myself so made the mistake of having someone else do something I should have done. Oh well, live and learn.
Onto the problems.
Tachometer: The tach is doing some funky fluctuations when moving down the road. I can hear the engine enough to tell it isn't fluctuation like the tach so I think the problem may revolve around a lose connection somewhere. This problem just started recently.
I'm getting a wierd clicking noise that seems to be coming from center or passenger side under the dash when the ignition is on. But it's intermittent and is not always there. The Blower Motor Does work.
And I can't remember the rest at the moment. LOL
Any ideas on those two?
Thanks,
Larry
Old Mar 27, 2006 | 04:27 AM
lightshow's Avatar
Default RE: 1982 accord few issues..
what motor did you swap? either way the distributor should have a blue wire coming from it which is the tach wire. thats probably loose. clicking noise? id have to hear it
Old Mar 27, 2006 | 04:33 AM
gsdreams's Avatar
Doh, Now I feel stupid. I swapped out the Coil Wire after the idiot that swapped the engine for me didn't get it on tight and wiggled lose to spark and catch fire. I probably tweaked the wire when I was putting the Coil Wire on.
The engine came out of an '82 Prelude. Same 1.8L Long Block as is used in the '82 Accord. The Exhaust, Intake, and Transmission were all kept from the Accord.
Old Mar 27, 2006 | 04:37 AM
gsdreams's Avatar
To add the clicking sounds electronic. I just can't trace down what under the dash it could be coming from other than I suspected the Blower, but that is working properly and this sound continues with the blower off........
Old Mar 27, 2006 | 04:56 AM
lightshow's Avatar
maybe the clicking noise is from the ignition. not the electrical part but the mechanical one.
Old Mar 27, 2006 | 05:07 AM
gsdreams's Avatar
I'm running through my mind of what is on the Passenger Side or Center for the ignition and can't think of anything that could be causing this sound.
It is Definitely NOT coming from the drivers side. And it appears sometimes when the car is not running.....
Old Mar 27, 2006 | 02:50 PM
lightshow's Avatar
behind the glove box is the main relay which comes on when you click the key on. there is a mechanical lever in the ignition that activates this relay...its the same part that makes the sound when the key is in and you open the door and hear that noise.
Old Mar 27, 2006 | 02:58 PM
gsdreams's Avatar
I really need to get a Service Manual for this car. Both Haynes and Chilton are trash for this year.
I will check that, hopefully it isn't the Main Relay. Dealer quoted $345.00.
Old Mar 27, 2006 | 03:03 PM
lightshow's Avatar
no no the relay is probably fine....when its bad your car doesnt start. im just talking about the ignition. probably if you pull it out and spray some graphite in there that might even fix it.
hhadisi
Jan 24, 2013 07:21 PM
floman
Feb 26, 2012 10:53 AM
floman
Feb 21, 2012 09:53 AM
82HondaLX
Oct 10, 2009 10:55 PM
GRAY WHISKERS
Apr 28, 2007 01:41 PM
