1984 Accord Timing Belt Replacement
Old Aug 16, 2010 | 10:30 AM
barnfindhonda's Avatar
Default 1984 Accord Timing Belt Replacement
I am new to this site and a new owner of a 1984 Accord. Bought it not running and diagnosed that the timing belt needs to be replaced. Going through the disassembly and realizing that this car will be a bit tough to work on because of the tight spaces to work in, (not exactly a chevy truck, my other vehicle).
My first obsticle is trying to reach and loosen the alternator adjustment bolt. Does anyone have a creative way to get to this? Looking for any other advice related to replacing the timing belt. Following the Haynes book step by step.
Thanks,
Scott
Old Aug 16, 2010 | 01:42 PM
Okieaccord's Avatar
Have you tried YouTube? I watched a video by "Davidsfarm" that was pretty good. I found the video a lot easier to follow than the manual.
Old Aug 17, 2010 | 10:54 AM
Default Bolt removed, new problem
Went to the local Harbor Freight and bought a ratchet with a long extension and got the bolt out.
Next problem, crankshaft pully bolt. I cannot secure the crankshaft pully from spinning to remove the pully bolt. This is because the timing belt teeth are stripped off and I cannot lock the camshaft pully. Any ideas? Oh, just to make sure, the crankshaft pully bolt is standard thread direction (counterclockwise to remove) right?
All help is appreciated!
Old Aug 17, 2010 | 11:35 AM
kris_loehr's Avatar
They make a tool to hold the crank pulley, so you can break the bolt loose which is a normal right handed threaded bolt.
Old Aug 17, 2010 | 01:52 PM
Thanks for the info. Going to buy a crankshaft pulley tool.
Old Aug 17, 2010 | 04:59 PM
Pulley has a large hex-shaped recess (55mm or something like that) - that's what the tool engages.
A home-made tool would be a big nut with 55mm(?) across the flats, with a hole large enough to pass the 17mm socket for the bolt. Then a big bar welded across that nut.
mark95
May 18, 2009 11:47 AM
insadj05
Apr 2, 2008 10:28 AM
Tony1M
Apr 1, 2007 05:42 PM
srt
Sep 27, 2006 02:17 AM
