1988 accord
Old Aug 21, 2008 | 01:30 PM
bkmartinturbo
Default 1988 accord
I have a 1988 honda accord 150k that was running fine one day. Now it wont ldle and it will barely pull itself around. It has a little valve noise. Could this be a timing belt that has skipped? Can this happen or do they always just snap and blow the motor? BK Martin
Old Aug 21, 2008 | 02:52 PM
cjdm98's Avatar
Default RE: 1988 accord
Have you checked your throttle body, TPS... anything ?
Old Aug 21, 2008 | 02:53 PM
cjdm98's Avatar
And a word of advice, Timing belt snap=Bye bye engine.
Or... some miracle of god it burst and you realize it immediately.
Old Aug 21, 2008 | 04:05 PM
Check everything else to rule it out. If the belt actually breaks, it would not run AT ALL. If it simply skipped a tooth or 2, itll run badly. All you have to do is take off the upper timing cover & check the camshaft timing. If its off, replace the belt. Dont take a chance by simply re-timing it.
Old Aug 21, 2008 | 06:45 PM
hondadude's Avatar
DX?,LX? or LXi? Carb or Fuel Injected? power windows? sun roof?
Just for grins and giggles, when was the timing belt last changed?
raydavid93
Mar 16, 2013 09:23 AM
gunns1983
Dec 5, 2007 01:38 PM
gunns1983
Dec 5, 2007 12:30 PM
Aphro
Aug 30, 2007 04:43 PM
RICHARD
Sep 10, 2006 06:14 PM
