1988 Accord LXi Fuel issue
Old Nov 20, 2008 | 08:38 PM
visualsmoke
Default 1988 Accord LXi Fuel issue
1988 Accord Lxi. Approx 215K on the old girl and she runs GREAT except for a pesky starting problem that rears its ugly head from time to time, and has done so now. Sometimes it refuses to start. Cranks over fine, but won’t run. It is getting spark, but no fuel. My friend the Honda guru says on this year Accord, there is a relay of sorts under the dash somewhere. This relay controls the fuel pump electrical supply. Its purpose, says he, is to prevent power from getting to the electric fuel pump in the event of a roll over accident if the car were to come to a stop inverted. He says this little relay is a small circuit board that develops hairline cracks due to vibration. The cracks intermittently cause the fuel pump to be shut off, and, hence, the hard starting issues. He also says this is most likely the fuel starvation issue and not the pump, as, if the pump quits, it done for good and won't start working again. Because my car has had this problem from time to time yet always seems to fire up again at some point, he may be correct. If it is this little tip over relay that's causing the problem, what is it called and where can I get a replacement? If you’ve any thoughts, or other areas I should look, those comments are very much appreciated. Thanks.
Old Nov 20, 2008 | 09:27 PM
hondadude's Avatar
Default RE: 1988 Accord LXi Fuel issue
90-93 had the main relay problem more so than any others.
You should be able to hear the fuel pump run the first few seconds the key is turned on.
Maybe have someone listen thru the fill port
There is an access hatch behind the rear seat /driver side, so you can go to the fuel pump connection and test for power to the fuel pump.
The Yellow wire at the pump connector is the power from the relay.
Old Nov 24, 2008 | 03:15 AM
visualsmoke
I listened through the trunk, right above the access panel that gives access to the fuel pump. No sound of the fuel pump operating. I'll try listening through the filler neckMonday. Thanks for the reply.
Old Nov 9, 2013 | 07:22 PM
Gloria Worrell's Avatar
Default 1988 honda accord lxi rotates but will not start
My 1988 Honda usually starts up after the engine cools off. Once it get hot it rotates and will not start. I put a new fuel pump and filter, spark plug wires distributor cap and rotor button in it. I need to know some feedback on what might keep the car from starting on its on.
Old Nov 10, 2013 | 06:31 AM
First, welcome to HAF.
Testing is needed but it sounds like the coil or ICM is getting hot and giving out......cools off then it works again. When the car dies, can you test for spark?
Also, just for grins, is your 88 carb or fuel injected?
raydavid93
Mar 16, 2013 09:23 AM
loadder
Sep 13, 2012 06:22 AM
jfcapps
Jan 12, 2010 04:51 PM
mainman1963
Nov 16, 2009 12:27 AM
caliass
Apr 15, 2008 10:20 PM
