1988 Honda Accord Hatchback Retractable Headlights
Old Apr 7, 2013 | 01:11 PM
dmanster1's Avatar
Default 1988 Honda Accord Hatchback Retractable Headlights
My headlights are in the up position and they won't go down when I turn the lights off. The lights go off, but they remain in the up position. Is there a fuse that might have blown or could the motors have died simultaneously?
Old Apr 7, 2013 | 01:50 PM
Hi new member...
I'm fairly sure that your motor is no longer working. Test the connections 1st to see if it's getting power to it's motor.
Old Apr 7, 2013 | 02:16 PM
i have to ask if the switch on the dash...just to the right of the steering wheel is pressed in?
To the right of the wheel is a set of switches....left to right.....Headlights up/down, dash dimmer **** (brightness of the gauge at night) and the rear defrost (if you have this option, you didn't give the trim level).
With the car off/keys out. Press the up/down switch for the headlights?
Old Apr 8, 2013 | 07:34 PM
dmanster1's Avatar
poorman212,
You sir are a Godsend. The switch was depressed. My problem is solved. I let my son borrow the car and when he returned it, he did with the lights up. He had no idea how he'd done it and it's been nearly 7 months since I've driven the car.
Thank you.
Old Apr 8, 2013 | 08:11 PM
Anytime
I'm a big fan of the 3rd gen Accords (86-89). Thanks for coming back with the answer.
surfngbob
Aug 6, 2013 05:46 PM
WILLYS60
Jun 24, 2013 02:25 AM
rjbdaddy
May 31, 2013 07:24 PM
raydavid93
Mar 16, 2013 09:23 AM
WindPhoenix
Aug 7, 2012 11:45 AM
