1988 honda accord HELP PLEASE
Old Apr 11, 2011 | 05:58 PM
sensi2011's Avatar
Exclamation 1988 honda accord HELP PLEASE
I have a '88 honda accord hatch, manual and carb.engine...
for the past week my car has been a total pain in the a**.
When it gets warm it dies out if i dont keep my idle high.i could be doing 70mph and it will die out if i drop it into neutral without revving it..anyone got any ideas please let me know..
Old Apr 11, 2011 | 07:28 PM
Most likely a carb problem. Check automatic choke is releasing (choke plate opening) as engine warms. If plate stays closed, the choke actuator is faulty (spring I think?).
Less likely is failed throttle cut that is closing (spring-closed) due to a faulty solenoid or circuit. The throttle idle position is held in place by a solenoid. If solenoid or driving circuit fails, the cut will not hold throttle plate in idle position and engine will starve for air (engine will stop w/o throttle held open manually).
Old Apr 11, 2011 | 07:51 PM
Will it do the same while sitting still and warm? Pull the top of the air cleaner, remove the air filter and the two 10mm nuts on the screen over the carb. Crank it up and look down the throat of the carb...do you see "gas" dripping?
Then pull the remain two 10mm nuts from the top center of the valve cover (holding the air cleaner). Three vac hoses that connect to the lower air cleaner housing (two on the right/pass side, one on the left/drivers side-as you lift it you will see them), look at the carb fuel level sight glass on the left/drivers side, what is it reading?
Old Apr 12, 2011 | 02:36 PM
sensi2011's Avatar
thanks for thee help
sensi2011's Avatar
yes it does the same when sitting and the engine is warm..
Old Apr 12, 2011 | 07:12 PM
You'll need to give some feedback on the items suggested before we can go further....can you smell gas when it shuts off....
I do have two of that gen carb models for reference if needed. Good luck
raydavid93
Mar 16, 2013 09:23 AM
dudebb
Nov 29, 2009 05:57 PM
kylefaust
Sep 7, 2008 02:48 AM
russo_p
Apr 22, 2008 11:09 PM
kylefaust
Mar 25, 2008 08:38 PM
