Can you problem solve this?
Old Apr 12, 2011 | 07:46 PM
dmrush1's Avatar
Default Can you problem solve this?
I have a 99 Accord, manual transmission. Over the past few months, about 4-5 times, while driving, the engine will be running smoothly and then lose power for a split second(RPMs will go down), but not turn off and then continue to run smoothly for a few more weeks until it happens again. Lately, when starting the car, it will seem to start (sound and RPMs) as I turn the key, but as soon as I turn the key back, it will die. After a few times of this, it will adventually start. I've tried changing spark plugs. Any thought about what it might be?
Old Apr 12, 2011 | 07:52 PM
Can you check the elect part of the ign switch. Sounds like it is cutting out. Try wiggling the key while it is running, not a true test but will help.
Call the dealer to see if yours has been replaced under the recall...might get one for free.
"but as soon as I turn the key back, it will die"
Old Apr 12, 2011 | 08:09 PM
If you can get it to die by wiggling the key, that means it's the switch.
If you can get it to keep running by holding the key just a bit, not letting it completely spring back, that means it's the switch.
But if you can't make either one of those happen, that doesn't prove the switch is good. It could still be a bad switch, but needs more of a proper test.
Old Apr 12, 2011 | 08:30 PM
engtaz's Avatar
Almost A Senior Member
I have the same problem but key wiggle does not effect it. Mine is a lx 2.3 auto tran
sona1111
Mar 15, 2013 10:29 PM
pennsylvaniaron
Oct 24, 2009 12:20 AM
subby
Oct 23, 2006 09:58 PM
remington870_20ga
Jun 18, 2005 03:28 PM
