Pulling new metal EGR port plugs
Old Apr 12, 2011 | 07:34 AM
ronjr8102's Avatar
Default Pulling new metal EGR port plugs
I did the EGR port cleaning on my 93 Accord & didnt do every step to my liking. So I was thinking of doing it again cuz it was so quick. My question is has anyone tried pulling out the new metal cup shaped EGR plugs? Im afraid cuz they are so thin that when pulled with a slide hammer that they will just tear or split making more of a mess.
Old Apr 12, 2011 | 12:31 PM
If they're not expensive just replace them.
Only other possibility is trying to grab above-flush edges w/ needle-nosed pliers and work them up/out.
I suspect that required replacement is intent of new design. Old design solid plugs could be re-used by filling drill-through holes w/ epoxy. That won't work w/ a thin shell plug similar to a freeze plug.
Old Apr 12, 2011 | 06:18 PM
ronjr8102's Avatar
texashonda - they r a $1 ea, its not price. When I tapped them in I put them flush w/ the intake body so I can grab them w/ pliers. Im just curious if them being so thin that when I pull them they will tear cuz there is only one thread if that when the puller goes in (the brass plugs were a good 1/8"+)
Thanx
Old Apr 12, 2011 | 08:53 PM
Similar to old plugs, you'll have to careful not to rip the screw out of the body,... a lot more careful. However, I think you might be able to pry them out w/ a screwdriver punched through and under one side.
You might try to talk to a Honda mechanic who has some experience. I bet they know how to get them out.
huzzsaba
Jan 23, 2008 07:42 PM
accordfan222
Jun 1, 2007 08:25 PM
AccordEX
Mar 30, 2007 09:49 PM
nixalot
Jun 27, 2006 07:50 PM
Antwan
Mar 28, 2006 04:33 AM
