1989 Accord cold idle :)
Old Feb 25, 2017 | 09:47 AM
What I would do is take a look down the "throat" of that carb as it is running - yes you will have to use you hand on the throttle linkage/cable based upon your description - won't stay running unless you press the gas.
Are you seeing any gas "drops" or anything like that, might need a flashlight to get a good look.
Also look at the drivers/left side of the carb, there is a "sight glass" where you can see the level of gas in the bowl - again with age that glass "window" gets cloudy so a flashlight might be needed.
d0n
Dec 10, 2014 07:42 AM
Mrowkoob66
Nov 1, 2011 10:04 AM
tskw914
Nov 9, 2009 08:48 AM
spoconn
Aug 21, 2009 07:06 AM
mastar91169
May 11, 2007 10:36 AM
