1989 accord fuel pump relay image
Old Dec 30, 2012 | 08:34 PM
stubby1962's Avatar
Default 1989 accord fuel pump relay image
Hello All..I have been doing alot of reading concerning the fuel pump relay on a 89 honda accord lx 2.0, auto, carbed.. I have come to the conclusion that there are 2 different ones, but don't know which to buy. here are 2 pics of what I have read will fit.
I have been under the dash looking and have found the gray one mounted on the back of the fuse box, but cannot find the other one, so I'm guessing the 1st one is right for my car, cause I can't see or find another one. What do you all think?
I had to replace the fuel pump and found it straight wired.. I check the harness and it was getting no voltage, so I'm assuming the relay is bad and want to change it out so I can remove the hot wire running back to the pump..
Thank You and God Bless US All..John
Old Dec 30, 2012 | 10:54 PM
Here is the site showing the MFR location. The 89 location is towards the bottom.
Honda Accord Main Relay Location
This may be for the fuel injected accords. Poorman212 is more familiar with these accords and will hopefully post on here.
Old Dec 31, 2012 | 04:39 PM
The gray one is for the carb'd models (DX and LX).
The LXi's (Fuel Injected) take the second.
I'm a fan of testing things.....are you willing to do a bit of this before replacing the part?
Old May 2, 2015 | 05:10 PM
hondaqueen's Avatar
Default help
My 89 lxi is doing the same thing but I have searched high and low but have had luck can some one tell me where to find it at. Thanks in advance
Old May 3, 2015 | 07:46 AM
The LXi is fuel injected......
It is way up there to the left of the steering wheel.
You might remove the "coin box" and look through there, you can then see it.....the fun is getting it out once you see it.
Can I ask what issue you are having and what testing you've done to confirm the relay is bad?
Attached Thumbnails 1989 accord fuel pump relay image-3rd-gen-main-relay-location.jpg
Old Mar 30, 2025 | 07:17 PM
a1waysbroke89's Avatar
Default Voltage at fuse and none at pump
I’ve checked and have power at the fuse. I have no power at the pump. I want to check the relay because only every now and then it will work. When I bought the car the guy said he had it running but it was running very rough. Any idea of what may be the problem would be awesome.
greg05
Aug 31, 2009 05:32 PM
kissbally78
Jan 18, 2009 07:14 PM
bambooyou
Sep 1, 2008 11:21 AM
smittyjs
Jun 24, 2006 11:22 PM
quietgiant
Apr 1, 2006 01:05 PM
