1990 accord doesn't start when hot
Old Jul 11, 2007 | 06:26 PM
Mcgill224
Default 1990 accord doesn't start when hot
Sometimes when the weather is above 90 degrees and I have driven a short distance and turn the car off, it will not start for 5-10 minutes. It cranks strong but its not getting any fire. Thinking it may be the Ignitor or coil both cost around $70 each. Any ideas where they are located on this car or tips for replacing???
Old Jul 11, 2007 | 08:47 PM
ricj
Default RE: 1990 accord doesn't start when hot
Should have something to do with the main relay. If not, then get the car decarbed and even get the intake manifold cleanup real good. A good scanner will give the exact answer to the problem.
Old Jul 12, 2007 | 11:27 AM
hondadude's Avatar
this sounds like a classic case of bad solder joints in the main relay.
you could also test for battery voltage to the Black/yellow wire at the dist. when the key is turned on.
If you have power there the problem could be the coil/ignitor, they are both under the dist cap.
gasface11
Jul 11, 2012 12:33 PM
rampcrawler
Jun 28, 2012 09:27 PM
bpethomas
Jun 5, 2012 10:47 AM
Devil Strider
May 31, 2012 09:21 PM
gwalker
Apr 20, 2008 11:35 PM
