1990 accord ex ignition problem
Old Mar 19, 2006 | 11:49 PM
deserthonda's Avatar
Default RE: 1990 accord ex ignition problem
First off no need to disconnect the battery........Trust me ...
You need a phillip screwdriver to remove the steering wheel covers , both lower and upper,5 or 6 screws,, the switch plugs in the fuse box under dash, left side , unplug the switch, follow the harness,, there are 2 screws you have to remove to separate the electrical part from the mechanical part ,, they are not 8 mm ,, they are either 5 or 6 mm ,,( I believe 6 mm ) you need a 1/4 inch socket and rachet to remove those ..
Once removed, unclip the harness ,, install all in reverse order, make sure to route the harness properly or the steering wheel covers will not fit properly
Old Mar 20, 2006 | 01:17 PM
stigedis's Avatar
SO BY LOOKING AT THE SCHEMATICS, THE PIECE I NEED IS THE WIRE HARNESS FROM THE IGNITION. THE SIDE OPPOSITE THE KEY?
SO IF I GOTO THE DEALER I CAN SOUND LIKE I KNOW WHAT I AM TALKING ABOUT
I WILL TAKE IT APART AND CHECK IT OUT TONIGHT.
THANKS FOR ALL THE HELP....
Old Mar 20, 2006 | 03:14 PM
tell the dealer the year and model of your car and tell them you need
the electrical portion of the ignition switch ,,,,,,,,,,,,they will know what you are talking about and you will sound like a MASTER TECH
Old Mar 23, 2006 | 10:30 AM
stigedis's Avatar
Thanks for everybody's help. I replaced the electrical component in the ignition ($50), and she fires right up. Problem solved.
Good to go here in MN...
mike
Old Jan 17, 2008 | 10:23 PM
Mikebike125's Avatar
ORIGINAL: deserthonda
Does the SRS system and airbag need to be disabled to perform this switch replacement?
shehadehd
Sep 20, 2012 05:20 PM
alternety
Jan 3, 2011 07:54 PM
Nstarr
Aug 25, 2010 01:40 PM
phil068
Oct 29, 2009 02:17 PM
brofrank
Feb 13, 2006 02:58 PM
