1990 accord lx clutch pedal? problem
Old Sep 5, 2008 | 09:46 PM
bunkrd you
Default 1990 accord lx clutch pedal? problem
it is a manual 5-speed
so i really dont think its the actual clutch, but today when i got home from school my brother said that the clutch gave out and so i went to check it out well apon inspecting it i noticed that before the clutch almost had a spring feeling like you know if you let go it will "pop" back out but now what happens is the pedal will be completly out and you tap it(not hard) and it will go all the way to the floor. and then you have to pull it back out. so basically there is only two ways the clutch pedal could be posistioned, all the way in or all the way out
let me know what you guys think it could be
also i had the clutch out and car wouldnt start but with the clutch all the way in it would start
Old Sep 5, 2008 | 10:05 PM
Default RE: 1990 accord lx clutch pedal? problem
It is likely the master or the slave cylinder. Look for a low brake fluid level in the master cylinder level. Look for fluid leaks.
Old Sep 5, 2008 | 10:35 PM
bunkrd you
what about a snapped brake cable.
Old Sep 5, 2008 | 11:17 PM
There are no cables with the clutch pedal. It is all hydraulic.
Old Sep 6, 2008 | 08:48 AM
JohnL's Avatar
ORIGINAL: bunkrd you
The brakes having nothing to do with the clutch, and in any case are hydraulically operated except for the handbrake (which has a cable).
99% you have air in the clutch hydraulics, so in the short term you need to bleed the system. In the longer term, air entered the system for a reason, you need to locate the leak and fix it. In the meantime, you'll need to keep a very close eye on the clutch fluid level.
Old Sep 6, 2008 | 10:18 AM
Peel the boot back on hydraulic slave cylinder at transmission bell housing, front of engine, near radiator. If any fluid is present, a new slave cylinder or kit will be needed. If no fluid, look for leaks on back side of master cylinder on firewall beside the brake fluid reservoir. Likely one of them is leaking. Easy fix.
Old Apr 9, 2016 | 11:34 AM
Low94's Avatar
I have a 94 accord and it used a little bit of clutch fluid. Did similar but my pedal stuck to the floor. Have small amount of fluid in boot of slave cylinder. R&R it and problem fixed
uh-60mechanic
Apr 26, 2013 08:09 PM
stephen94accord
Aug 21, 2009 09:58 PM
robertomiguel
Mar 24, 2008 07:25 AM
matash
May 3, 2007 02:39 PM
tamb
Jul 21, 2006 01:05 AM
