94 accord clutch pedal losing pressure!!!
Old Aug 20, 2009 | 07:33 PM
stephen94accord's Avatar
Default 94 accord clutch pedal losing pressure!!!
94accord ex v-tech manual. I have replaced my clutch master, my slave, and finally my CLUTCH!!!!! Everything was fine for a few weeks now it's losing pressure. AGAIN!!! I can pump the hell out of it and it'll work for a short time. I exchanged the slave for a new one. Didnt work. Should i try exchanging the master a well??? SOMEONE give me some ideas PLEASE!!!!!!!!!!!!!
Thanks, Stephen
Old Aug 20, 2009 | 11:48 PM
deserthonda's Avatar
i would first chk for any sign of leakage,( hoses. lines, reservoir) , if no leaks at all,,make sure that system was bled properly ,, if it was,, I would have to go with a new clutch master cylinder ,,
Old Aug 21, 2009 | 09:58 PM
polacek's Avatar
Any leaks from under the car after it has been parked for a while. I have an air horn installed in the engine compartment. After about 3 years, it rubbed on the clutch line enough to cause a pin sized hole. Since it is aluminum, I used a torch with solder. Good as new.
Luckyluciano
Aug 4, 2012 02:18 PM
ginag
Dec 6, 2011 08:33 AM
planeteclipse
Apr 26, 2011 05:19 PM
stephen94accord
Aug 10, 2009 10:15 AM
tamb
Jul 21, 2006 01:05 AM
