No pressure in clutch pedal
Old Aug 4, 2012 | 12:09 PM
Luckyluciano's Avatar
Default No pressure in clutch pedal
Ok so I have 94 Honda accord ex and about two weeks ago my clutch pedal dropped straight to the floor I had to get it towed checked the reservoir and it was empty the next morning checked the slave cylinder and there was fluid all under the rubber boot so I had that and the master cylinder changed alright regained pressure in the clutch drove it for a little why went to work attempted to leave work and there wasn't enough pressure in the clutch to shift into any gears so I threw it in first drove for maybe ten minutes all in first gear btw and regained enough pressure to shift gears my first initial thought was I may still have air in the system took it to Kramer tires they bled it and now my clutch pedal is back on the floor im hearing so many different things that could be wrong from a leak somewhere in the line but im not losing any fluids to my throw out bearing being out but I'm not hearing the sounds from the tranny that would indicate that being a fault .. Any help would be greatly appreciated
Old Aug 4, 2012 | 01:01 PM
Was the slave cyl changed? You had fluid under the boot and replaced the master cyl? I'm lost again.
Old Aug 4, 2012 | 01:08 PM
Yes both the slave and master were changed
Old Aug 4, 2012 | 01:10 PM
I meant fluid on the rubber part that you pull back on the slave
Old Aug 4, 2012 | 01:23 PM
So you replaced the clutch master and slave, correct?
You bleed it and it works for a bit?
I'd inspect the hose (I think this gen had a rubber hose) and be sure it isn't "sucking" air back into the system.
Old Aug 4, 2012 | 01:57 PM
Yea changed the master and slave bled it it's like it will hold pressure fine for a few hours I'd be at work when it's time to leave try to put it in reverse still a little pressure but not enough to get into gear ride 1st for a little while about ten minutes and the somehow I'm able to develop enough pressure to push on the clutch to change gears and checking this hose you mean the Hydrolic one I'm assuming how do I go about checking it to fine any type of air being sucked in and are you ruling out the throw out bearing or anything in the transmission because I'd hate to have to drop it again
Old Aug 4, 2012 | 02:06 PM
Sounds more in the clutch hyd system than a clutch/trans issue.
You want to be sure the clamps on the hose are tight........but don't break anything.
The rod on the master cyl "could" be out of adjustment?
Debate starter here.....for bleeding the clutch, which is hard, I'd suggest a speed bleeder to help. Some don't like them, I agree that using them for brakes is a waste of money and time but on the clutch system I believe they are worth it.
Old Aug 4, 2012 | 02:18 PM
Ok I'll definetly try to find one of those so it's more than likely air still trapped in my system because my reservoir is full right now none is leaking out anywhere that I can see
eduard
May 9, 2013 12:11 AM
planeteclipse
Apr 26, 2011 05:19 PM
stephen94accord
Aug 21, 2009 09:58 PM
piconrule
Jul 24, 2009 02:38 PM
tamb
Jul 21, 2006 01:05 AM
