clutch losing pressure 94 accord
Old Jul 22, 2009 | 09:27 PM
stephen94accord's Avatar
Default clutch losing pressure 94 accord
(94 accord ex)I replaced my clutch, clutch slave cyl and clutch master cyl. For one reason or another my clutch pedal keeps losing pressure. I bleed it and its fine for half a day or so then i half to pump it to rebuild pressure at a stop light. The kicker to me is it is NOT losing fluid. Does anyone have any ideas????
Thanks, Stephen
Old Jul 23, 2009 | 10:12 AM
Since it's not losing fluid, that pretty much narrows it down to the master cylinder. That's the only place where it can leak back into the reservoir. But it's new, so ????
Old Aug 10, 2009 | 08:13 AM
greenray
try to bleed the slave cylinder again. sometimes you can have an air bubble that takes awhile to bleed out.
Old Aug 10, 2009 | 10:15 AM
How are you bleeding it? I've occasionally had trouble when pumping the pedal, if I let the pedal snap suddenly upwards. Control the pedal so it doesn't snap up.
eduard
May 9, 2013 12:11 AM
ginag
Dec 6, 2011 08:33 AM
stephen94accord
Aug 21, 2009 09:58 PM
piconrule
Jul 24, 2009 02:38 PM
tamb
Jul 21, 2006 01:05 AM
