1990 accord lx gas saving help
Old Jun 15, 2010 | 07:31 PM
churritos567's Avatar
Default 1990 accord lx gas saving help
im trying to make it save some more gas what else should i work on?
i am going to replace spark plugs and wires
change air filter
clean injector
is there anything else i should look at?
thanks
Old Jun 15, 2010 | 07:59 PM
Replace distributor cap and rotor, if they are due.
Also, make sure the air pressure in the tires are all at the recommended level. That recommended pressure is on a sticker on the driver's door jamb.
Old Jun 16, 2010 | 07:08 AM
Honda seems to like NGK spark plugs best.
General clean-up. Dirty throttle body & throttle plate? Got any vacuum hoses that are getting old & cracked? Eliminate any vacuum leaks.
Got a timing light? Advance your spark timing a bit but keep it inside the acceptable range.
Check whether your brakes are dragging?
Suspension alignment and/or replace worn shocks (IF they're worn).
When it's time to replace tires, there's some models that have less rolling resistance - usually labeled as "energy-saving" or Goodyear "Fuel/Max" or something like that. They are generally NOT the more sporty - performance tires so you gotta make the choice.
But the most important, most influential thing BY FAR is how you use your right foot.
Jun 8, 2011 02:13 AM
Peter Lawrence
Mar 12, 2009 02:38 PM
jphill0
Jun 2, 2008 09:49 PM
HuYnHness
Sep 5, 2007 07:08 PM
tallgood
Apr 16, 2007 11:12 PM
