1990 honda AC
Old Jun 19, 2010 | 07:58 PM
You need to find & fix the leak.
Old Jun 19, 2010 | 08:02 PM
jumped_it's Avatar
I did not pull a vacuum ... I used the first can to try and bleed out any air that could be in the line. Could the vent problem be caused by air still in the line?
Old Jun 19, 2010 | 08:12 PM
Yeah, that'll cause uneven temperature across the face of the evaporator. Incorrect pressure can cause that too. Try a can with dye so you can find the leak. Or find a shop with a leak detector (sniffer).
After you fix the leak then have it evacuated & filled by weight. That's more accurate than filling by pressure. (But filling by pressure is way more accurate then just guessing) Adding cans of refrigerant & bleeding it out is a real poor way to remove the air. It'll take forever to get all the air out.
Old Jun 19, 2010 | 08:32 PM
Air in your system will cause it to run poorly. Air doesn't compress to a liquid like R134a, and it won't bleed out.
Jim is correct, you need to find and fix the leak.
You car is 20 years old, so all of the o-rings are probably brittle. A bad shaft seal is another location for a leak.
What I did was dismantled the system. Replaced all of the o-rings and used Nylog o-ring lubricant to help keep the rings lubricated. I replaced the shaft seal (I can give you more detailed instructions), because I wanted to make sure that I did it right the first time and would not have to repair the a/c for a long time. I also bought a new receiver/drier and expansion valve. I drained all of the oil from the system, and used oil that was made for R134a. Once the system was back together, I pulled a vacuum to remove the air, and waited for an hour to make sure it held a vacuum (it did). Then I added the R134a. It has been working fine since then.
Old Jun 21, 2010 | 09:22 AM
jumped_it's Avatar
Thanks guys ... The air actually started to blow cold out of all of the vents ... but I'll be buying some dye and searching for a leak in the very near future. I appreciate all of the help and direction.
gnozahs
Aug 3, 2007 05:09 PM
codybergendahl
Jul 12, 2007 02:57 PM
loopster
May 20, 2007 11:27 AM
Etther
Aug 30, 2006 08:35 AM
j
Mar 17, 2005 11:08 PM
