Transmission Problem
Old Jun 21, 2010 | 10:16 AM
dloughridge's Avatar
Default Transmission Problem
I have a 91 Accord LX 4 cyl automatic. This weekend I changed both CV joints. Car did great. Drove it about 9 miles. Parked this morning and when I put it into drive it just sat there. Just like in neutral. When giving it gas the speedometer moves up and down, and I can feel it shifting. When putting it back into park it wants to grind. Any ideas out there. It is a one owner with 58000 orig miles.
Old Jun 21, 2010 | 11:12 AM
Axles weren't snapped completely into the transmission?? So they've slipped outwards just enough to disengage the splines. Try snapping the axles back securely into the transmission. Sometimes it takes a good bit of force to snap into place.
Old Jun 21, 2010 | 11:21 AM
Thanks, I'll give that a try tonight.
Old Jun 21, 2010 | 02:57 PM
You'll know right away if that's it because you'll be able to pull the axle out from the trans without much force.
trouble
Aug 21, 2012 07:46 PM
MessAround
Aug 13, 2011 09:45 AM
mamarotta
Nov 13, 2010 11:10 AM
kellysa111
May 1, 2009 08:35 AM
Krashnpa
Jan 15, 2006 12:57 PM
