1990 Honda Accord EX
When I had a 95, the Helm book explained it like this...
If the ECU is OK & there's no error codes stored, then it's like this:
When you jumper the SCS connector, the check-engine light will stay ON solid & not flashing.
If the check-engine light is lit up while driving, and jumpering the SCS connector shows NO flashing codes, THEN you suspect a bad ECU.
The SCS connector is that blue-plastic plug which you jumper with a paperclip to read the CEL error codes. Jumper that, key on, & the CEL will flash the error codes.
This isn't really a PROCEDURE, so I'm gonna move the thread over to General Tech.
gnozahs
Aug 3, 2007 05:09 PM
loopster
May 20, 2007 11:27 AM
