1990 honda accord ex F22A1 motor CEL CODE 43
Old Sep 29, 2010 | 12:25 AM
churritos567's Avatar
Default 1990 honda accord ex F22A1 motor CEL CODE 43
i pulled a check engine light code and it read it was 43 four slow blinks and 3 fast. i just read it was the fuel supply system, where should i start inspecting the problem?
thanks,
Richaerd
Old Sep 29, 2010 | 12:33 AM
g22cd5's Avatar
Supper Moderator
it's your fuel filter or pump. Can you hear he pump prime when you turn the key...turn the key to accessory and listen for the pump to prime...it will come from the back seat
Old Sep 29, 2010 | 12:37 AM
the fuel pump works i hear it going and then the click when the key is on and hte cel turns off. when im driving to school its life after five miles in the freeway it turns on. could that be my fuel pump still or is it my fuel filter triggering it?
Old Sep 29, 2010 | 01:03 AM
The code 43 means that the engine computer is having a problem with the air/fuel mixture. Some of the causes can be from a weak fuel pump, clogged fuel filter, bad fuel pressure regulator, or the oxygen sensor. There are other possible causes as well.
If you search through the forums, most of the time it is an O2 sensor problem. If you go that route, buy a Denso brand, because they make the sensors for Honda and will be less expensive.
Old Sep 29, 2010 | 12:44 PM
Okay because i also pulled another code 1 which it the o2 sensor im planning to replace that and then the filter if the problem occurs. or do you prefer something different
Old Sep 29, 2010 | 01:25 PM
That sounds like a good plan.
Old Sep 30, 2010 | 01:19 PM
hondadude's Avatar
The dreaded code 43;
This one was lost in translation from japaneese to hondaeese, and english-eese.
The O2 sensor is reading 'unburned' oxides; aka a rich burn condition.
So don't waste time or money buying a fuel pump, though a fuel filter might be due.
The O2 sensor could be the cause as well as old plugs, poor spark, IACV screen plugged up, throttle body needs cleaned.
Khai Son
Mar 14, 2012 11:32 PM
HALX9091
Feb 13, 2012 01:55 PM
tingjunkie
Sep 17, 2010 06:37 PM
Stener75
Jul 25, 2010 08:21 PM
91accord84
Sep 21, 2009 01:28 PM
