1990 Honda Accord NO spark
Old Jun 25, 2012 | 09:39 PM
Are you in the states, has the motor been changed?
Will you post a pic of your wires?
Old Jun 25, 2012 | 10:10 PM
I think the picture was taken as if the camera were on the firewall.
Old Jun 26, 2012 | 11:51 AM
rampcrawler's Avatar
first pic is under the distributor where i found the ground connection without a wire, the wire you see coming out of it is the one i put in and ran to the valve cover. the next 2 are of the lower cooling hose to the back of the engin by the fire wall. original engin with 350K on it. ruff start this morning got it going after about 30 sec of chug chug chug ran fine took it out for a ride went to auto zone and because its a 90 they cant run codes came home let it sit awhile started up just fine WTF
Old Jun 26, 2012 | 09:12 PM
Could be the ground was bad ?
For codes, check the "Common DIY Threads" sticky at the top of this section for "how to" get them on this generation Accord.
Old Jun 27, 2012 | 01:48 PM
found and cleaned ground car is running great THANKS TO ALL OF YOU
Old Jun 27, 2012 | 08:01 PM
Thank you for coming back with the answer.
90snowman
Jan 27, 2024 10:26 AM
sirtwist2
Sep 24, 2012 01:36 AM
DoPeFiSh
Apr 23, 2011 02:08 PM
SeanAccord
May 18, 2010 08:24 PM
j
Mar 17, 2005 11:08 PM
