1990 Honda Accord Transmission
Old May 22, 2010 | 04:06 PM
finkjac13's Avatar
Default 1990 Honda Accord Transmission
I own a 1990 Honda Accord Lx.
Well about a week ago i had to replace my shift control cable and got it installed but not adjusted, due to being late for work. So when I would start the vehicle it would start in reverse. Other than that their were no problems the rest of the day.
Then later on before i adjusted the cable, when the car was in reverse it would make a loud grinding noise with no reverse power. Which i knew wasnt good. So i adjusted the cable and hoped the grinding would be gone, but it never went away.
So my question is: Do i now have to replace my transmission?
Old May 22, 2010 | 05:58 PM
deserthonda's Avatar
i would make extra sure that the cable is properly adjusted first ..i am assuming it is a AT tranny..........did you adjust the cable at the center console pin?? remove the pin and make sure that the cable is lined up properly ,,if not adjust by the 10 mm nuts till it is lined up
Old May 24, 2010 | 10:02 AM
finkjac13's Avatar
Yes it is an automatic.
I am pretty sure it is properly aligned because every other gear (P,N,D3,D4,2,1) engages with no problem.
Unless Reverse is real touchy?
stutla22
May 13, 2014 12:41 AM
alternety
Jan 3, 2011 07:54 PM
hatzipri
Nov 29, 2008 10:05 PM
bassbanger
Oct 28, 2008 11:49 PM
buz
Mar 5, 2007 02:15 AM
