1991 Accord automatic transmission problem
Old Sep 19, 2008 | 09:28 PM
scasper
Default 1991 Accord automatic transmission problem
I have a 1991 Accord with an automatic transmission. The engine and trans were pulled from a '92 with 90,000 miles.
The problem issometimes the transmission shifts and kicksdown fine, other times, it will not kickdown at all and shifts thru all gears at about 3200 rpm at wide open throttle. The kickdown linkage is adjusted correctly from what I have read. It does not seem to make any difference if the engine is warm or cold.I have tried cleaning all of the electrical connections going to the transmission. I have checkedthe trouble codes, no transmission codes come up.
Any suggestions?
Thanks!
Scott
Old Oct 5, 2008 | 10:10 PM
scasper
Default RE: 1991 Accord automatic transmission problem
Update:
I swapped the engine and transmission ECU's from the '92Accordthe engine and trans came out of. It seems to have taken care of the problem-for now.
I will post again if the problem comes back.
CB7-SE-1991
Jan 29, 2013 04:45 PM
slavbrod
Sep 27, 2012 09:34 PM
foxies
Dec 23, 2010 05:31 PM
King_d
Aug 14, 2010 10:29 AM
