1991 accord changed trans now turns over but wont start
Old Jun 18, 2011 | 06:09 PM
  #31
I'm sorry, the ECU fuse in the fuse box under the driver's dash. The cover for the box should have a label on it for the ECU fuse. The owner's manual should have that information.
I think that I have the pins labeled correctly. The main relay gets power from 3 different sources on 3 different pins. Check that fuse first. I'll see what other info I can find.
Old Jun 18, 2011 | 06:14 PM
  #32
themachinist1's Avatar
yea i checked all them fuses and there fine i have the print out on the inside of the cover
Old Jun 18, 2011 | 06:16 PM
  #33
and the voltage is right i have 12v on 4 and 6 and thats it when in II position
Old Jun 18, 2011 | 06:20 PM
  #34
ill put a brand new one in for giggles
Old Jun 18, 2011 | 06:25 PM
  #35
Something isn't quite right here. Are you using the numbers that I posted before for the electrical connector, show below?
1 2 X 3
4 5 6 7
Old Jun 18, 2011 | 06:31 PM
  #36
im about to start taking pictures of everything and see if it goes from there, im getting frustrated, are any of the larger black or green relays that are near or on the fuse block associated with any of this stuff. im sorry i dont use a question mark to punctuate my question button dosent work along with the letter p, though i can aste in the p
  #37
yea its right i got voltage on 4 and 6
Old Jun 18, 2011 | 06:38 PM
  #38
Yeah, post some pictures.
The problem is that every diagram has the same function at every pin, even though they number them differently. If you use my numbering system, then something is way off.
I know this may be a stupid question, but are you sure this is a 91 accord?
Old Jun 18, 2011 | 07:19 PM
  #39
could b a 92 but its deff an accord
Old Jun 18, 2011 | 07:24 PM
  #40
Here is what I have for the main relay for numbers, wire colors, and description. Are these the same wire colors?
Numbering on plug to main relay:
12-3
4567
1. grn/blk________ goes to ECU
2. blu/red________12V when key in start position
3. blk___________ground
4. yel___________goes to fuel pump
5. blk/yel________12V when key in the II position
6. yel/blk________goes to ECU
7. yel/blu________12V
