1991 accord changed trans now turns over but wont start
ok i see whats going on your looking at it from the back where the wires go in and im looking at the front...i think i need to re test this. i real sorry somewhere alon the way i though you said to disconnect the connectors from the relay and test this. im gonna lug it in and test the number 4
I think that I understand the confusion. I'm numbering looking from behind where the wires enter the connector and you are numbering looking at it from the pins.
Lets stick with my numbering to make life simpler.
You have the proper voltage at the pins 5 and 7. The relay switches power to #4 going to the fuel pump, so that test is good.
Turn the key off. Use a wire to jump pin 4 (yel) to pin 5 (blk/yel). Turn the key to the II position. Do you hear the fuel pump turn on?
