1991 accord changed trans now turns over but wont start
Old Jun 18, 2011 | 07:24 PM
  #41
themachinist1's Avatar
i can post some but were talking about the same connector and the top has 3 leads w 4 spaces and the bottom has 4 and im doing it like you said
Old Jun 18, 2011 | 07:25 PM
  #42
ill go look
Old Jun 18, 2011 | 07:33 PM
  #43
with the wire colors u had i have this 3+21.
7654
Old Jun 18, 2011 | 07:34 PM
  #44
so with that being said i have voltage on 7 and 5
Old Jun 18, 2011 | 07:35 PM
  #45
and number 4 that goes to the pump has no voltage at the connector so.......what now
Old Jun 18, 2011 | 07:38 PM
  #46
and to clarify if using your numbering its 1 blk 2 blue red 3 green blk 4 yel blue 5 yel blk 6 blk yel and 7 yellow
Old Jun 18, 2011 | 07:43 PM
  #47
ok i see whats going on your looking at it from the back where the wires go in and im looking at the front...i think i need to re test this. i real sorry somewhere alon the way i though you said to disconnect the connectors from the relay and test this. im gonna lug it in and test the number 4
Old Jun 18, 2011 | 07:47 PM
  #48
well never mind my blabbering i rechecked it with it connected and its still no voltage on number 4
Old Jun 18, 2011 | 07:50 PM
  #49
I think that I understand the confusion. I'm numbering looking from behind where the wires enter the connector and you are numbering looking at it from the pins.
Lets stick with my numbering to make life simpler.
You have the proper voltage at the pins 5 and 7. The relay switches power to #4 going to the fuel pump, so that test is good.
Turn the key off. Use a wire to jump pin 4 (yel) to pin 5 (blk/yel). Turn the key to the II position. Do you hear the fuel pump turn on?
Old Jun 18, 2011 | 07:51 PM
  #50
I was typing while you were. Do this test with the relay unplugged.
