1991 accord changed trans now turns over but wont start
Old Jun 19, 2011 | 01:19 AM
  #61
themachinist1's Avatar
ok trying now
Old Jun 19, 2011 | 01:48 AM
  #62
ok my homie we got a running honda....though u gonna be mad when u find out what it was...u know that resistor we checked for the injector power, well since i didnt take the car apart when i started putting the stuff that i hadn't done back together i switched the source for this and one right next to it looping the source back through the system. its running though i did find that one of the collant sensors is broken the one under the distributor and when i got the car the wires had been pulled outa the harness for the o2 sensor so i got 4 wires that need a home
Old Jun 19, 2011 | 02:05 AM
  #63
hope u not too frustrated, it was an honest mistake, especially since i didnt dismantle this area and the plugs are the same and close enough to switch which generally they make ones close together a diff harness so this doesn't happen
Old Jun 19, 2011 | 02:07 AM
  #64
I'm glad you got it running. Some of those electrical tests were giving strange results, so I'm glad you figured it out.
Were the wires pulled from plastic connector for the O2 sensor, or on the side of the engine wire harness? what are the wire colors?
Old Jun 19, 2011 | 02:22 AM
  #65
the side from the engine to the o2 sensor, the sensor has its harness and wires and the engine side of the harness , the wires are two black a white and a green
Old Jun 19, 2011 | 03:00 AM
  #66
guess u crashed out
Old Jun 19, 2011 | 03:05 AM
  #67
The two black wires will go to the two wires on the O2 sensor that have the same color (likely black). The order should not matter.
Then you will have a 50/50 chance at the white and green wire.
Old Jun 19, 2011 | 03:44 AM
  #68
ok so then i guess i switch them if the car stil shows a code
Old Jun 19, 2011 | 03:48 AM
  #69
btw thanks for sticking with me on this, i feel much better now that its running and i might not have figured it out had we not been testing all these things, i woulda just kept on thinking that i had done all the setup work right...this just goes to show that if you are going to endeavor on working on a car that someone has already worked on its hit and miss sometimes with the rebuild of something you didnt take apart and are not familiar with...though i feel good about the things i did and glad i learned some things
Old Jun 19, 2011 | 09:13 AM
  #70
We'll I happy for you as well. Been folowing for a few days now....sorry I should not have jumped in the middle yesterday.
