1991 Accord Problems
Old Sep 9, 2011 | 11:53 PM
You need to figure out why neither pin on the fuse box for fuse #27 has no power.
When you test those pins, do you touch the red lead of the volt meter to one of the pins, then touch the black lead to a good ground, like the valve cover bolt? I just want to make sure that you are testing it properly, so you are not mislead by your readings.
Old Sep 10, 2011 | 12:58 AM
Stan22490's Avatar
I started getting desperate and tried removing the relay and using a direct cable and it got the windows working. Gonna try replacing both relays and see if that fixes my windows and go from there but my dash still isn't working. (DAMN)
Old Sep 10, 2011 | 07:19 AM
Hang on, are we testing for the door locks or the windows?
Old Sep 10, 2011 | 12:28 PM
Stan22490's Avatar
Neither was working but now the power windows are working
Old Sep 10, 2011 | 02:31 PM
Good, one down. BTW, what solved the windows?
Are you still looking to figure out the door locks? If so let us know what you've been able to find out so far.
Old Sep 10, 2011 | 04:11 PM
Stan22490's Avatar
I don't know if its fully solved with the windows but if I arch a cable across the 12v section it then powers the other fuses so im gonna get another relay and see if it was just bad.
Would be nice to figure out doors but I think its something in the drivers door only because no matter which power lock I hit theres a noise in driver door so gonna take that apart later today when I'm home.
More importantly is the console because nothing on it works (speedometer, temp, fuel, Odometer, Lights on console.
Any help is appreciated
Old Sep 10, 2011 | 04:26 PM
  #17
Please check the Common DIY Threads at the top and download (free version) or buy a manual. It will help in finding the issue. Do you have a volt meter? You can test the relay.....I'm thinking the realy is fine, it is either the ground or hot side of the relay "coil" that is the issue.
Old Sep 11, 2011 | 01:08 AM
  #18
Stan22490's Avatar
Couldn't find another relay at any store but took mine apart and re-soldered it together and now all the relays works fine. YEAH!!
However my dash is still not working at all and i'm not sure where to start. Also the fan blower is not working and those are the only important things that I care about so any help is appreciated.
Old Sep 11, 2011 | 08:08 AM
  #19
Lets start with the dash. Test the dash dimmer switch.
Old Sep 11, 2011 | 09:41 AM
  #20
Stan22490's Avatar
My bad that doesn't work but I will check the switch but more importantly the tach, Speedometer , any gauge is not working
